Originally Posted By: artificialist
I'm used to these engines lose a quart after 1500 miles, but the rate you burn oil is far from average.
Sometimes if the engine wasn't properly maintained, piston rings can get stuck and cause more oil burning.
Be sure to check you PCV valve and hoses, and I only recommend a real MOPAR PCV valve.
You can check the PCV valve but burning a little oil going over the mountains can/is normal. If going 75mph at 4000rmp up a grade of 6 plus for several miles with a full load.... yeah, lost oil.
