The only vacuum you want is in the intake manifold. When the piston travels down on the intake stroke with the intake valve open, a vacuum is created by the downward motion of the piston. The principle works exactly the same as a medical syringe. Pull the syringe, liquid flows into it. Push the syringe, liquid flows out of it. You don't need a vacuum in the crankcase where the oil fill hole opens up to. You want the crankcase to be at atmospheric pressure. However, sometimes the crankcase will get pressurized if the piston rings are worn out and pressure is escaping past the rings on the compression stroke.
