In the ten years since I converted my Briggs to paper filters. I have had to change the elements only once. If I had stayed with the oiled foam, I would have had to clean and reoil everytime I mowed. That gets old very quick, especially when you have mow dry and dusty lots filled with rocks and mesquite tree thorns. I guess if you only mow pristine lawns oil foam works just fine.
