I have a 98 dodge neon I use for autocross and track days only. I typically run redline 5w40 or 10w40, but I get free cases of M1 0w40. is it up to the task?
Oil temps run 200-230 degrees. Hot oil pressure at idle is around 35 psi in the block and 20 psi in the head. The car has a built high compression engine. I'm using a high volume oil pump. The rod and main bearing journals of the crankshaft have been polished to allow a slightly larger oil clearance. It usually runs in the 4,000 - 8,000 rpm range. I use a purolator pure one synthetic filter.
