OVERKILL
$100 Site Donor 2021
When I had my Magnum smogged, it blew zero across the board. No carbon monoxide, no unburned fuel, no NOX. And there are two tiers of vehicle that are CLEANER.
0.0 on HC, CO, & Nox?....Impressive, Hard to believe on a Chrysler LA/"Magnum" engine though.
2007 Dodge Magnum, 5.7 Hemi. It's a Tier II ULEV. Test was IM240 roller dyno.
I just read your sig, Figured you were talking about your 5.2L, Do 2007 Hemi's still use Waste Spark/Dual plug like the earlier ('03-'05) versions? I always thought it was odd for such a newer design engine to use 80's technology.
80's? Dual ignition dates back to the early 1900's and was implemented to deal with improper/poor flame-front propagation on large bores. It's implementation on the modern "semi-hemi" was done for emissions, as, IIRC, poor swirl characteristics at low intake velocities allow for incomplete combustion with single plug ignition.
I remember fondly a boat from my youth, a vintage Minette from the late 1920's with a Van Blerk huge i4 with dual ignition; two distributors slightly out of phase with each other. Surprisingly common for the era.
