Hi guys, another UOA I'm posting for Best F100. Enjoy!
Code:
EQUIP. MAKE/MODEL: Ford 2.5L 4-cyl Hybrid
FUEL TYPE: Gasoline (Unleaded)
OIL TYPE & GRADE: Toyota 0w-20
OIL USE INTERVAL: 5,372 Miles
It's hard to say what your max oil change interval can be on this oil. We can say "longer" for
sure -- and we'd suggest about 7,000 or 8,000 miles for next time. If that sample comes back good, then try
going a little longer. It's hard to say when you'll reach that tipping point since so many factors go into it (use,
contaminants, the oil TBN, etc.). The oil should be fine for you for the summer. There was a little fuel, here,
but everything else looks
nice and strong as well.
ALUMINUM 1
CHROMIUM 0
IRON 5
COPPER 0
LEAD 0
TIN 1
MOLYBDENUM 329
NICKEL 1
MANGANESE 0
SILVER 0
TITANIUM 0
POTASSIUM 0
BORON 74
SILICON 12
SODIUM 3
CALCIUM 2212
MAGNESIUM 11
PHOSPHORUS 669
ZINC 781
BARIUM 0
cSt Viscosity @ 100°C 50.4
SUS Viscosity @ 210°F 7.38
Flashpoint in °F 375
Fuel %
Antifreeze % 0.0
Water % 0.0
Insolubles % 0.2
TBN 5.2
TAN
ISO Code
Note: 2 QTS API SM + 3 QTS API SN was used.
Code:
ALUMINUM 1
CHROMIUM 0
IRON 5
COPPER 0
LEAD 0
TIN 1
MOLYBDENUM 329
NICKEL 1
MANGANESE 0
SILVER 0
TITANIUM 0
POTASSIUM 0
BORON 74
SILICON 12
SODIUM 3
CALCIUM 2212
MAGNESIUM 11
PHOSPHORUS 669
ZINC 781
BARIUM 0
Fuel %
Antifreeze % 0.0
Water % 0.0
Insolubles % 0.2
TBN 5.2
TAN
ISO Code
