I read the recent post about the member who recently performed the "piston soak" on his Cobalt and got wonderful results!
I've read, on several occasions, about some BITOG members who perform this maintenance task, and it's prompted a few questions...
1 - What prompted you to perform this task?
2 - What's the underlying "root problem(s)" that created the situation that you needed to perform a piston soak? Is it, typically, one underlying problem with your motor that creates this need? How do you prevent the problem(s) from reoccurring?
3 - Would you think of a "piston soak" as a maintenance item that would be good for any car/truck, or only those that exhibit certain problems/behaviors?
4 - Are there specific products designed to be used for this purpose?
Thank you for the explanations!
Ed
Ed
