I bought KYB pre-assembled struts for my Ford Escort to replace some rear struts with broken springs. I got one of them in with no issues, but I can't get the other one to line up properly. I finally stood it up next to the old one and realized that when I have the mounting brackets lined up on the bottom of the strut (facing the same direction), the studs on the top are slightly off. I need to either turn the strut mount plate clockwise or turn the piston counterclockwise to make it line up. How do I do this? Do I need to use a spring compressor and then loosen the center nut to make the mount turn?
http://s18.postimg.org/ylt0ndbqx/IMG_4078.jpg
