Originally Posted By: Hokiefyd
Here's my Torque screen:
This is after my drive home from work yesterday. Comments on the gauges:
Fuel Flow: I believe fuel flow is an OBDII parameter and not calculated by Torque. The units are gal/min, and I've set the gauge to show from 0 to 0.1. You can see that my peak fuel flow during my trip home was about 0.047 gal/min. It will flash up to about 1.1 or 1.2 gal/min during WOT, but I like to see the resolution on the graph at lower flows. This graph will show the engine going into fuel cut-off mode during deceleration. In fact, you're
seeing fuel cut-off in this screenshot; I was coasting as I took the picture. Normal idle fuel flow is just shy of 0.01 gal/min.
Engine Load: This graph is neater and neater the more you think about what it represents. It doesn't mean "load on the engine" in the intuitive sense. After all, this screenshot is during fuel cut-off: engine load should be ZERO, right?! No, the engine load parameter in OBDII is an estimation of the percentage of maximum torque available
at that engine speed, and it estimates that by measuring actual volume of air consumed divided by maximum air volume capacity at that engine speed. For example, you can be cruising along at 1,200 rpm at 45 mph or so and see engine loads of 50-70%. This means that, at that engine speed, the engine is consuming about half of the air that it can at that speed...even though the throttle may be only cracked open. That's because the engine can't consume nearly as much air at 1,200 rpm compared with what it can at 6,000 rpm. It's neat to load it to 100% with the throttle pedal, and observe the engine "climbing out" of that torque hole...as engine speed rises, it has the capability to consume more air...but if you leave the throttle at the same opening, the engine load will decrease as the engine speed rises.
They say that it's normally best to accelerate in the 80-90% range, in terms of engine load. Once you get to 100%, the engine is giving you all it can
at that engine speed, and opening the throttle more will generally consume more fuel than what you gain out of the engine...until it really gets up into its torque peak. Obviously, how all of this interplays depends highly on engine size and number of cylinders, but the OBDII concept remains consistent. This is one of the most useful parameters, in my opinion, if you're looking to get the most out of the fuel you're using.
Coolant Temp: pretty self-explanatory. The CR-V runs right at 188-190 deg F most of the time. If I sit idle with no A/C on (so no rad fans running), the temperature will climb to about 210 deg F before the fans kick on, and fall back to about 205 deg F before they turn off.
Intake Temp: the temperature yesterday was about 62 deg F at the time of my drive home. Intake temp will rise fairly quickly when stopped, and will fall again pretty quickly once moving. It always runs, however, about 10-20 deg higher than ambient, once everything's warmed up.
Vacuum: Torque displays this as a combined Vacuum/Boost gauge. During vacuum, it displays in in/Hg. If it goes to 0 vacuum (or boost), it switches to PSI. I'm not sure how it derives both units of measure from one physical sensor, unless it's an estimation of either or both. Manifold vacuum is similar to engine load: once you approach 0 vacuum, you're getting the most you can out of the engine at that speed. You can also use manifold vacuum to assess the efficiency of your intake system at WOT. At WOT, my manifold vacuum drops to less than 1 in/Hg, and actually goes to 0 or 0.1 psi sometimes. It's said that they design intake systems with odd plumbing and resonators and chambers to enhance airflow and to even produce a supercharging effect. It's cool to be able to watch that in action.
In general, one really needs EITHER engine load OR manifold vacuum, as they're essentially linear inverses of each other. Idle in my car (as you can see above) is about 24 in/Hg. 50% engine load is about 12 in/Hg. 90-100% engine load is about 0-3 in/Hg.
I don't have Torque running all the time, but when I do, these are the things I watch. Our 2008 CR-V has a very fast OBDII system, and the gauges update in nearly real-time. Our 2005 MDX must have a slower OBDII protocol, because I get updates about once a second or so on the gauges. So its usefulness for seeing detailed changes in these measurements is somewhat limited.
You gotta pay for it though
