I read before on another forum that someone fixed their worn, dying power steering pump by adding MoS2 and that was the only thing they found besides replacement that got good results.
I had about 1/4 bottle of MoS2 left in the garage along with a half bottle of Rislone p/steering fluid + stop leak. I syringed as much of the old stuff out the pump as I could (only about 300ml) and replaced with the 1/4 bottle of MoS2 and topped up to full with the Rislone. I am hoping it will fix the small p/s leak as well like it did my engine with it's plating effect.
I idled the car for about 5 minutes for the pump to mix it up and I went to turn the wheel and it was already much smoother! It is normally very stiff for the first 10 minutes when cold and when it's at full temp it's nice and easy but has a shudder.
So far no more stiffness or shudder!
I will see how it goes after my 30 minute commute to work in a couple hours and report back.
Can anyone think of any cons of using it in the p/s?
Thanks
Thanks
