I'm posting this UOA for Best F100.
Code:
EQUIP. MAKE/MODEL: Ford 2.5L 4-cyl Hybrid
FUEL TYPE: Gasoline (Unleaded)
OIL TYPE & GRADE: Motorcraft Synthetic 5W/20
OIL USE INTERVAL: 5,387 Miles
This first sample from your Fusion looks really good. Wear metals are about as low as you could hope for.
Universal averages show typical wear levels for this type of engine after about 5,200 miles on the oil. You're beating
those numbers by a mile. The viscosity was correct for 5W/20 and no fuel or coolant showed up. Low insolubles and
silicon show good oil and air filtration. The TBN was 2.4 showing some active additive left; less than 1.0 is too low for
extended use. This engine can definitely handle a longer oil run. Try 7,500 miles next time.
ALUMINUM 2
CHROMIUM 0
IRON 3
COPPER 0
LEAD 0
TIN 0
MOLYBDENUM 50
NICKEL 0
MANGANESE 0
SILVER 0
TITANIUM 0
POTASSIUM 0
BORON 213
SILICON 2
SODIUM 1
CALCIUM 2399
MAGNESIUM 20
PHOSPHORUS 783
ZINC 950
BARIUM 0
cSt Viscosity @ 100°C 51.9
SUS Viscosity @ 210°F 7.84
Flashpoint in °F 390
Fuel %
Antifreeze % 0.0
Water % 0.0
Insolubles % 0.2
TBN 2.4
TAN
ISO Code
Code:
ALUMINUM 2
CHROMIUM 0
IRON 3
COPPER 0
LEAD 0
TIN 0
MOLYBDENUM 50
NICKEL 0
MANGANESE 0
SILVER 0
TITANIUM 0
POTASSIUM 0
BORON 213
SILICON 2
SODIUM 1
CALCIUM 2399
MAGNESIUM 20
PHOSPHORUS 783
ZINC 950
BARIUM 0
Fuel %
Antifreeze % 0.0
Water % 0.0
Insolubles % 0.2
TBN 2.4
TAN
ISO Code
