Originally Posted By: user52165
Originally Posted By: SilverSnake
Originally Posted By: philipp10
Just because the mfg put a 5 year shelf life on it doesn't mean squat. They must have felt they had to put some date but I can assure you, they did'nt run any type of test to prove it. Even so, I would probably use it in a older car or lawn tractor than one of my newer cars. Bet anything though that it is fine.
Doesn't mean "squat" to you but means something to me. I am not one of those individuals that thinks everything a manufacturer says or does is a conspiracy to screw the customers. Where is your evidence that the manufacturers did no tests on old oil before establishing a shelf life? What qualifications do you have that would have me lean toward accepting your "assurances."
What qualifications do you have that it is not OK?
I have no qualifications. Re-read my post. I stated that "I am not one of those individuals that thinks everything a manufacturer says or does is a conspiracy to screw the customers." If the manufacturer tells me that an unopened oil container has a 5 year shelf life, then I believe it.
So, instead of listening to people like you, I will go with the advice provided by the petroleum engineers who developed the product. Here is one example.
I sent Exxon Mobil an e-mail in December 2014 and asked the following question: “I know you state that the recommended shelf life of motor oil all types is 5 years. What specifically happens to the oil that makes it unwise to use after the 5 year period?”
I got the following answer:
“Dave: The oil tends to break down after the 5 year interval along with the additives and viscosity and would not protect your engine like the oil within the 5 years.”
How about your qualifications user52165???
