Originally Posted By: IveBeenRued
I've had good luck with Amsoil Signature Series 0W-20. Wear metals over longer intervals using Amsoil were lower than M1 AFE on a shorter interval. Iron was 5PPM and 8PPM over 6.5K and 10K miles respectively using Amsoil vs 10 PPM over a 6.5K interval. Aluminum was 0PPM and 2PPM over 6.5K and 10K miles respectively using Amsoil vs 2PPM over a 6K mile run using M1 AFE.
I have no numbers for Castrol Edge Titanium(current fill) or M1 EP (waiting on rebates or it's getting returned) but will at some point.
You can't compare small PPM variances between oils. See Doug's article on the main page.
Totally agree, that's why I currently have Castrol Edge in the car right now. I just go for whatever is cheap and has a good reputation on here.
