I recently had to e-check one of my kids 1995 Taurus 3.0. It is from Florida, so it is in pretty good condition body wise and drives pretty well. It failed the e-check for NOx, CO and HCL were very low. I checked the egr system and it seemed to work correctly. Apply vacuum to the egr valve and the engine runs rough and almost dies. I then drove it with a vacuum gauge connected to the egr valve line and it applied vacuum when warmed up and accelerating and lost vacuum when at idle. There is a small exhaust leak somewhere in the front exhaust between the manifolds and the converters. I don't think that would affect NOx because I believe they are only 2 way catalyers in 1995, but I am not sure. Any help would be appriciated
