I have a 2012 Toyota Highlander. I was considering installing a fumoto valve on my transmission pan. I need to crawl under and get a better look, but it appears that there is a plastic cover underneath with a small hole where you can see the AT drain plug. If it is recessed far enough, I'm thinking a fumoto with a short nipple (so I can attach a tube) would be a great way to do drains/fills without having to remove the large plastic cover. I've asked around and apparently the factory drain plugs are not magnetic, so I'm not losing anything there.
Questions for the board:
1) Does anyone out there use a fumoto valve for their ATs? I have them on the oil pans of both of my cars and LOVE the convenience. I've had them in service for over 10 years and they have never caused be a problem.
2) Does *anyone* out there have any clue what size valve would fit a 2012 Toyota Highlander (with the 3.5L v6) automatic transmission pan? I emailed fumoto and they didn't have that information.
Thanks!
Thanks!
