Hi, I'm a bit of a lurker don't post just browse a bit.I took a brief browse looking for some answers but I'm still a little lost. I have an 03 Silverado 2500 with a 6.0 gas. I am starting to use a little more oil than I should be. Roughly 1-2 quarts in 850 mile road trip. I was hauling about 6000lbs and with 4.10 gears my rpm is about 2300. I get no smoke at start up and do leak a little, I am going to clean up the engine and monitor that better. I have just over 200,000 miles and about 8500hrs run time. My questions are is there a huge difference in 5-30 oils such as Penzoil,Quaker State,Valvoline or Castrol. I get the difference between synthetic and high mileage oils but how about the basics. I'm also considering an additive to maybe condition/help my valve seals. I'm not expecting miracles just a little prolonged life from this engine before I swap in another.One of the local mechanics mentioned a flush with Seafoam in the oil then an STP additive, not sure which one however I will need to confirm which one.
