Small rust spots on roof
Ankeny, IA
Hey guys, was cleaning the F150 today and as I was doing the roof I noticed 5-7 spots where the paint had chipped and it had rusted. Its only surface and the largest spot is probably the size of a nail head. What is the best way to reverse this? I've seen some terrible rusted roofs here in Iowa and I don't want it to get any worse then it currently is. Its the only rust on the truck too (as far as I can see) so I want to keep it nice. Thanks!
Originally Posted By: HerrStig
Acid rain a problem there?
I'm starting to think so. I've seen roofs completely paint stripped and rusted
They sell something like a small marker with glass fibers that will sand small spots. You do not want to make it larger. If you can get it to bare metal then a self etching primer and a topcoat.
You may need to deal with the rust with POR-15 or Eastwood Rust Encapsulator.
Rust has to have oxygen, so anything that seals it should stop it, but being on the roof oil based products wouldn't last long.
that's what you get for living in Agony, Iowa.
