Yesterday my aunt's '04 Impala 3.4 wouldn't start. Went to look at it, it would crank, but not fire. Then I opened the hood. Had her crank it, and I found there was smoke coming from the starter while cranking. Ok, fine. I tested the starter at a parts store. It was bad, and the smoking repeated (whew, not her wiring). Bought a reman starter and installed it.
I hooked the battery back up, and the starter instantly engaged. Oops, I think I hooked it back up wrong. So I reversed the two cables (as the third was tiny and couldn't hook up wrong). I reattached the battery cables, and nothing happened. Good.
I turn the key, and it fires up. But wait, what's that whine? Nothing seems wrong except that whine. So I shut it off. The whine SLOWLY quiets to a stop. I restart the engine. Same story, fires up but whines. It's the starter that's whining.
So if the starter engages when the key is turned, but quits when the key turns to off, it should rule out the ignition switch. The starter doesn't grind on the flywheel, nor does it instantly stop whining when the engine shuts off. To me, this says the starter constantly has power when the key is on, but the starter is NOT constantly engaged to the flywheel (meaning it is constantly spinning within its own housing). Does this sound correct?
What is my problem? Bad part or incorrect wiring?
Thanks in advance!
Thanks in advance!
