I unknowingly purchased an oil burner when I purchased my 350z Rev-up. Faulty rings and design on the Rev-ups simply means you have to deal with it. Some owners have had up to 4 engines replaced by the dealer, and still burn oil. I burn 1 qt every 250-500 miles.
It seems the burning stems from faulty piston rings, and the unnaturally high vacuum of the engine on deceleration, will suck oil past the rings. A clogged PCV valve exaggerates the oil burning problem because of even more increased vacuum within the plenum (no controlled vac leak).
A solution I have pondered, was a reversed boost-controller, to provide a mild vacuum relief at a certain vacuum level. The relief valve is closed at -21hg/in, or what ever idle vacuum is, and the relief valve opens at something like -25in/hg allowing. It sounds like this would alleviate vacuum inside the combustion chambers on heavy deceleration. It doesn't look like the ECM adjusts fuel/timing on deceleration above 1500rpms, so I cannot see a negative affect of a large vacuum leak on deceleration only.
This would solve my consumption problem. I have tested 500 miles of driving by doing absolutely no engine braking or coasting in gear. No oil consumption.
I have searched, and came up empty handed with any examples. Does anybody have knowledge of a vacuum leak on deceleration causing engine damage?
Thanks!
Thanks!
