Originally Posted By: JHZR2
It is related to the shift interlock since I can feel some faint remnant of the "click" in the selector handle.
I guess what I should have phrased is should I be concerned?
Here's the deal: no issues ever with going in and out of park. But with the pedal depressed, especially if it stays depressed with a change in the pedal position, the relay clicks over and over.
This didn't used to be the case.
It only happens with the selector in park.
So should I be concerned? The fact that this behavior only started recently is what bothers me.
Main concern is it stranding me due to being stuck in the wrong condition, or a malfunctioning relay/switch causing an intermittent parasitic drain.
Hopefully it's just the brake lamp switch confusing the BCM and as a result the shift interlock solenoid. The brake lamp switch is $10, no big deal. If your brake lights weren't working, this part would be the obvious culprit.
But with your brake lights coming on, it may not be. The signal from the brake lamp switch goes to the body control module, which then turns off the lock solenoid in the column, releasing the lever.
GM BCMs from the 1990s to pretty much now aren't the most robust things. The S-Series doesn't seem as problematic as some models, but there are Impala BCMs we keep in stock at work.
The solenoid in the column can go bad too, and would be the source of the click you feel in the shifter handle...but it is obviously releasing like it is supposed to, so I think it is more likely that the solenoid is getting a bad/confusing signal rather than having a problem itself.
I'd start with the brake lamp switch since it's cheap and easy. Throw the old one in the glovebox as a spare. If that doesn't do it, there may be emerging issues with the BCM. Pretty much impossible to say if/when it will cause it to get stuck in park. It may keep doing what it's doing now the rest of the time you have the truck with no additional symptoms, or the next time you drive it, it won't come out of park. With the engine off, and column unlocked, you should be able to get it into neutral, then start it up and shift into gear to get where you need to go.
