We bought a used 2013 Toyota Venza from a very upscale Cadillac dealership in Houston with only 16,000 miles on it and it was like brand new. Well, it just rolled over 20k so I proceeded to change the oil today. The filter is the cartridge type that has the plastic type housing. Well, the dealership had tightened it so tight that my normal socket wrench could not break it. So then I got out my rubber hammer and started trying to knock the wrench in the open position which did not work and then tried hitting it with a small maul. I the got out my torque wrench which is about 18" long thinking it would break it with the added leverage. Still no luck. I even tried a 1 1/2" three foot long PVC pipe to try to break it and it just started to round out the inside of the filter socket. So, finally out of desperation I got out my impact wrench that I use on lug nuts and finally, with that, I got it to loosen! THAT is why I do all my own work if possible!
