On sand rails, I've seen people use a flexible, removeable caulk where their air filter meets their carburetor to seal out any chance that any sand might make it past that point and into the engine.
I'm thinking about doing the same thing with my truck - use a small amount of flexible caulk inside the air cleaner assembly and then replace with a new OEM air filter. I'm thinking that would be a pretty easy way to confirm that 100% of the air will flow through the filter.
I'm sure the OEM filters do a pretty good job of making an air tight connection, but this seems like a pretty easy and harmless way to make sure of it!
Does anybody know of a flexible type caulk that I might use? Would it need to be something that's "high-temp" stuff? I wouldn't think it would get particularly hot inside an air cleaner assembly, would it?
Thank you,
Ed
Thank you,
Ed
