Hi:
I have a 1994 2wd v-6 PS AT AC Dakota standard cab. I need a new trans pan.Dorman sell a 265-827 which some say will fit. Dorman tech support say NO because they don't list 94 trucks although it seems to be same trans. After discussion they say it also has a deeper pan and "may fit" but not clear because its 2wd. I don't know about the crossmember clearance but I normally use 235/75 15 on factory alloys and the truck sits significantly. Oddly enough, I also have 215/75 15 snows on later factory alloys - never installed. Dorman say pan fits later Dakotas and RAM 1500, 2500, etc. for sure. Thoughts? I've seen both ways and have not found an exact year match. Thanks!
