When a scanner is hooked up, I get codes p0150 and p0325, the 02 sensor and knock sensor. The CEL is not on, though.
Another question, the CEL doesn't turn on at startup (like most cars do, when the first couple seconds the lights flash). However, the light does illuminate in KOEO. But like I said, scan tools agree that the CEL isn't on and wouldn't be on anyway.
I'm probably going to replace the knock sensor and oxygen sensor when I replace the valve cover gaskets, but just checking to see if something besides those two would cause hesitation.
