Originally Posted By: HTSS_TR
Originally Posted By: SilverSnake
A lot of the newer vehicles have greatly extended service intervals or no service for the life of the vehicles on the fluids you mentioned. I recently purchased a 2014 Ram and 2015 Challenger. Both vehicles do not need transmission (8 Speed Automatics) or differential service for the life of the vehicles. Fuel filter service is not required as well. Coolant is 10 years or 150,000 miles. No mention of brake fluid or power steering fluid changes at all. For these vehicles, engine oil and filter, cabin air filter, engine air filter, and tire rotation is about all that is needed.
Strangely, my wife's 2011 BMW 328i calls for brake fluid changes every 2 years. It is the first of over 80 vehicles I have had in my lifetime that call for regular brake fluid replacement in the Owner's Guide.
Most German vehicles has DOT-4 brake fluid and 2 years is the recommended change interval. For DOT-3 brake fluid the change interval is usually 3 years.
Mercedes is the same, every 2 years. I remember with a Ford, they never really had a flush interval, but I'd have it flushed when doing pads. When I didn't do it, the wheel cylinders would rust out.
On some Mercedes transmissions they originally said it was lifetime fluid, then said it just needed to be changed once at 39k, now I think people just do it every 39k. They use a weird fluid though, ATF 134 which you don't normally see. Same with the differential and transaxle, supposed to be lifetime, but 39k works.
As for Ford transmissions, I think AX4N calls for 30k fluid change, but the filter is supposed to be good for 150k which is why the pan gasket is reusable. I changed it every 30k-40k anyway.
