Hi guys, i'm new here and wanted some advice/opinions on my recent UOA. I was curious to know how the oil was performing so I took the sample early, therefore the oil had only run for 3000 miles. Here are the details:
2013 Toyota GT86.
13,000 miles (supercharged at 11,000 miles).
Daily driver. No track work but not babied either.
Oil temps on street during summer is approx 220-230. With spirited driving during summer I've seen temps shoot to 240.
Oil analysis performed by:
http://www.roktex.com.au/
water 0
lead 1
calcium 2603
oxidation 123
boron 0
zinc 1048
molybdenum 140
copper 2
fuel dilution 2
Viscosity at 100 9.6
phosphorus 0
magnesium 8
tin 0
nickel 2
TBN 9.1
nitration 11
sodium 5
aluminium 3
silicon 29
iron 9
FTIR soot 9.7
chromium 0
"Silicon is at 29ppm. Silicon is a highly abrasive material and can cause accelerated wear. Check air intake system. Viscosity @40 decreased to 54cst. 2% Fuel Dilution Detected. The presence of fuel can indicate faulty injectors, pumps or liners leading to poor combustion. Excessive idling/incorrect timing could also be a possibility. Oxidation and Sulphation are elevated. Oxidation is caused by abnormal combustion, high temperatures, oil aeration and high levels of copper. This can increase oil viscosity and leave piston deposits causing piston rings to stick."
My thoughts are:
1) Silicone levels - dirty air filter. I've ordered a new one.
2) Oxidation levels - due to the ester based oil, yes? So is this normal for this oil?
Should I stick to this oil spec again, or go thicker? The factory spec is only 0w20 and I'm worried about going with something too thick. In fact I was considering doing 50/50 Redline 5w30 and 5w20. What do you think?
