Originally Posted By: Gebo
So I can pull out that black connector?
If you ever need to remove that, squeeze the tabs together at 12:00 and 6:00 o'clock in the picture and pull. The same way you squeeze a close line pin. The other tabs at 9:00 and 3:00 o'clock in the picture are for retaining that large weather boot.
It's looking like your battery was not being charged by the alternator and that's why the car died. Your car was running off the battery as long as it could until it died out. The battery is supposed to be used for starting the car and then the alternator replenishes the power used up during starting. After that, all electrical requirements are provided by the alternator.
