Aside from price and availability, is there any reason to prefer 1 design over the other?
The first filter is an OEM Mahle for various Volvo applications. Where the center of the filter makes contact with the mount on the vehicle, it has a fiber like cloth. When the cap is re-installed, it gently smashes the filter inside the housing and securely holds it in place. In this case, the entire end cap is made of this material but with other Fram, Purolator, M1, Driveworks, etc. they have a ring of fiber material around the center tube, but are essentially the same concept. (On a side note, the AAP DW filter for this application seems extremly stout and comparable to Fram's filter.)
This is the WIX made Microgard, but all WIX made filters are like this. It is basically just a plastic cage and fits extremely snug inside the housing and (for me) is difficult to remove. (It literally felt like i was going to break something.) I am curious if it is too tight and will not have any play once installed like the above filter design and perhaps not seat properly. They seemed built very well, but I am not too impressed with the WIX design for this application. (Plus even with oil special deals, they are $$$.)
Could it also be possible that the "plastic-only" design on the contact area wont create a snug seal and allow partial bypass?
