Not sure this is the right forum, but anyway: I just bought a Bell Aire 5000 tire inflator from AAP; $41.xx with a coupon code and store pickup. The one piece that was missing from my in-trunk "be prepared" kit.
None of my tires was low, but just to see how it worked I pumped a coupla psi's into the left front, which was a hair lower than the right. Seemed to work fine; did not take long, though it was not much air, as noted. My issue with previous, less powerful inflators that friends have used (and once I used on behalf of a very car-phobic lady) is that it took forever to make any impact on a very low or flat tire.
This is the second-best/most expensive inflator Bell Aire makes. Figured it's worth it to get a good one if I'm gonna get anything.
Anyone have or use one of these?
Thanks.
Thanks.
