Originally Posted By: antiqueshell
For ordinary passenger vehicles you NEVER tighten oil filters with a wrench, only hand tighten, usually it is anywhere from 1/4 turn to 3/4 turn. Yet here we are speaking of this and any shop you care to mention will indeed tighten that filter with a darn wrench....usually so tight that in order to remove it the next time, you need to destroy it to get it off, absolutely ridiculous!
I have seen filters loosen on a longer OCIs when hand tightened (because it is simply dependent on how strong a person's grip might be) and of course, I am not talking about nearly twisting the filter off of the block nozzle with a wrench--that is beyond stupid. 1/4 to 3/8 of a turn past hand tight is not too tight, nor will it kink the gasket and while you will need a wrench to take it off, I will bet a free OC that it will not loosen or leak either.
