I just added an '05 LS430 to my stable. As you can see, I have older vehicles. I've read a lot about the differences between Toyota SLL Pink vs Toyota LL Red. I have no problem with the shorter change interval with the Red. The '05 only has 67K on it and I'm gonna switch over from the Pink to the Red. What procedure would you follow? I know about the engine drain cocks on both sides of the V8 so I can get a really good drain out. Plus, I have 8 gallons of Red on my shelf.
