Originally Posted By: Hootbro
Originally Posted By: DuckRyder
While that is true, in practice all they have to do is say no and then you are stuck putting pressure on them and perhaps getting it to court... I'll wager Honda has more lawyers on the payroll than the average consumer.
I simply don't understand why anyone would risk (no matter how small the risk) that aggravation over less than $100.00 with of oil.
If you want a check in the "win" column for internet discussion of the topic, you got it in spades. Everything you say is correct in a world of absolutes.
The point others are bringing up is that the use of 5W-20 name brand synthetic like the OP mentions for a couple of OCI's vs. the recommended 0W-20 and having a problem is so minute that you have a better chance of getting hit by a bus than some potential oil related issue here.
Only on BITOG do people pick the fly sh!t out of the pepper over such things.
Better chance of getting hit by a bus after being struck by lightning.
OP, use the 5w20. I did the same in the wifes CR-V so I could use up the last of my PU.
If your concerned about warranty, by a jug of 0w20 and keep the receipt on hand. Use the 0w20 once you have exhausted your 5w20.
