Some of you will remember my a build up in one of my engines that was pure MoS2.
I think i finally found an explanation.
This 3800 GenII is turbocharged and although run on synthetic oil it was mostly pre GF-5 with a HTHS of about 3.1. Later i started using HTHS 3.8 in it but most of the deposits were probably already formed.
Quote:
MoS2 has caused problems in some formulas. In rare instances the compound can come out of solution and form deposits. This is a particular problem in turbocharged applications...
The ILSAC GF-5 and/or Dexos approvals should remove the possibility of MoS2 deposit problems in low HTHS applications. Liqui-Moly has established an excellent reputation for using MoS2 in high HTHS applications without any deposit problems.
Not a knock of MoS2 just an reasonable explanation.
This article is worth bookmarking IMO. Its just info, feel free to rip the article to shreds if you don't agree, i didn't write it.
http://www.diagnosticnews.com/oil-additives-supplements/
