Donald
Thread starter
So I looked through the access hole. The pipe from the kitchen sink is slanted horizontal for about 15' in my crawl space , then vertical where it meets the 4" main which is fine. I looked through the access hole and also aimed my IR thermometer. The last 2' of the vertical pipe is 28 degrees but the rest is above freezing. I put a small electric heater in the access hole blowing into it. But the pipe is 15' away. Its 26F outside today.
