Earlier tonight, I had a car that gave me some challenges with diagnostics. Just wanted to share the experience with the group.
Vehicle: 1996 Infiniti I30, 3.0L V6
Mileage: 109k
Background: We had just replaced the spark plugs, intake manifold gaskets, coolant cross-over pipe gaskets, cleaned the EGR (and associated plumbing) and cleaned the IAC.
Issue: Upon starting up the car (after reassembly), we noticed a fairly rough idle. After a short test drive, a P1105 code was set. P1105 is for MAP/BAR Switch Solenoid Valve. This was the only code found.
At this point, we re-checked the connections to the MAP but found no issues. We could've thrown a new assembly at the problem, but we decided to look a bit deeper.
Relevant Scan Tool Data:
At idle:
Short-Term Fuel Trim, Bank 1: 3%
Short-Term Fuel Trim, Bank 2: 25%
At 2500rpm: No change.
At this point, I suspected that the vehicle was running lean for some reason. We re-checked for vacuum leaks and found none. We then decided re-check the connections at the injectors on Bank 2; at that point, we found that the connector for the injector at cylinder #2 was not fully seated!
Cleared codes, test drove the car again. Fuel trims are now normal, car idles normally and no pending/active codes were found again.
Moral of the story: Don't replace parts before doing a proper diagnostic! When we saw the P1105 code, we could have assumed that we needed to replace the assembly...but the issue turned out to be different.
Mileage: 109k
At idle:
