Originally Posted By: joel96
Gokhan, that pic is for Toyota vehicles. Everyone else recommending OEM parts, great, but I need a link to the OEM part; Hyundai hasn't documented their parts specs well; most of the sites I'm finding list the part and no other information about it.
I like the idea of a company specifically geared towards electrical wiring for vehicles. I need to know exactly what I'm supposed to use for the '03 Accent: the cable length, guage (Advance Auto Parts displays 4 AWG as compatible), diameter of lug rings, and which cables are included. I'm probably going to buy the terminal clamps seperately in order to pick higher quality ones (GenuinedealZ has some for 3/8" lug rings--the same ones are available on Amazon; they're brass wing nuts, unknown bolt composition, unknown terminal composition with expoxy coating); that will help when the clamps fail before the cable does; I need to know the diameter of the terminal clamps (or the diameter of the battery posts) and the diameter of the bolts . The failed clamp is on the negative cable. If I'm ordering custom cables, I'm going to need to find out about whether or not those little ground wires are going to need to be spliced in with the rest of the cable on the negative one. It appears that positive cables have to have those ground cables; positive cables have two lugs on them; this mean I need two cables for the positive cable?
Anyone have a good reason not to go with heavy wall versus standard lugs?
A 3' 4AWG with heavy wall tinned copper 3/8" lugs with heat shrink would be $8.17 from GenuinedealZ; that's well within budget. I can re-use the automotive tubing from the old cables to keep it protected from friction wear. The positive cables are a different story, since the terminal and cable setup looks more complicated; I still don't understand what the requirements are supposed to be for the ground cables, where they're attached, guage, length, etc.
Check http://custombatterycables.com/ if you have a aux cable coming off of one of the main cables. They look like they can do this.
