1982 Accord, 1.8, manual.
-When I got the vehicle, it would run. But, the operating temp idle was a little wonky. It would bounce around a bit. Then, one day it died.
- Now, it starts, runs at cold/high idle (3000+rpms - does that seem high?). It also seems to sometimes even rev up a bit from there.
-Once warm, the engine dies. Pressing the gas will not keep it running.
I changed the fuel filter, and tried a different fuel pump. I've also used some carb cleaner (just sprayed it in).
Problem persisted.
Thoughts?
Problem persisted.
Thoughts?
