2005 V-6 Merc Mariner has an oil leak at the interface between the block and the girdle above the oil pan. (Professional wrench has confirmed that is the source, and this is not unheard-of with this engine.) Due to the location, the fact that it is fairly minor, and that repair is prohibitively expensive, it will not be fixed, however the drip lands on the exhaust header pipe, so the burning-oil smell is present about any time the car is driven.
Question is, since the gasket is a silicone composition, is there any known leak-stop that could be added to the oil that would actually work? Most only are intended for rear seals, which are not generally silicone.
Thanks!
Thanks!
