I have seen when people have added too much LSD additive. Then when they change the fluid 30,000 miles later and add the proper amount of additive, the LSD magically starts working. I always start with no additive, If I get chatter, I add a little at a time til the chatter goes away. Keep in mind, it might take up to 100 miles for the LSD additive to mix in and stop chatter. Oftentimes people will drive it around the block, hear the chatter and add more. They are not giving the additive to take effect. Then when they add three times as much needed, they are perplexed as to why the LSD quit working.
