- Joined
- Mar 3, 2010
- Messages
- 2,451
So here is the deal, my expansion tank cracked as they typically do and I lost probably 2qts of coolant + whatever was in the tank.
I can't really wait a week to order g-48 BMW coolant from an online retailer and need to remedy this problem asap, the only close to g-48 coolant I can find is zerex g-05 at the local napa, will it be comparable and compatible if I top off with that?
For the record too I've already replaced the plastic water pump and plastic thermostat neck with metal so the only plastic left is the radiator sides and expansion tank.
