Stuck oil filler cap
Ohio
Go figure, the Traverse was reading a little low since I changed the oil ~4000 miles ago, and darned if the cap was stuck! A little coaxing got it off safely, but it seems to me it was sticky when I changed it, so I smeared a little engine oil on the O-ring. Anything better I should be using?
I've had this problem as well in my 20 year old VW Golf.
Over time the rubber degrades the heating and cooling cycles contribute to this issue. I wouldn't risk applying anything to it as long as it doesn't tear. Maybe use a bit of synthetic oil on it as I use dino in my car.
Originally Posted By: TallPaul
Need to carry a large channel lock pliers with you.
+1
Originally Posted By: Chris142
The cap on my jeep won't come off when its at normal operating temps.
LOL Several years ago I broke the ratchet mechanism on the oil fill cap of my 04 GC with the 4.0. Some materials change size with temperature more than others. I just got used to putting it on finger tight.
Same here.
Gates and Stant make an aftermarket cap that might come off easier, only costs about $3 on Rockauto each if you want to try one.
Gates Part # 31103
STANT Part # 10099
I did use channel lock pliers to unstuck oil filler cap few times before, I didn't know it was and is a common problem. I thought that I was getting weaker as I was getting older.
You mean to say some of you guys use tools to tighten/loosen the fill cap? I've always just presumed it just had to be finger tight and that's always what I've done. I don't even tighten it up much by hand, but as someone else stated if my engine is hot the cap is solid, I have to get a rag and really put some muscle into it and when it cools down it's easy to open by hand again
I oiled mine. No luck
Did you use 100% synthetic oil?
:p. Probably that goil junk, it cant even lubricate an o ring!
I think the plastic swells.
Most caps I see (or at least have problems with-- cough, GM, cough) have a cam-lock and 90 degree twist.
Our Libby 3.7 has the same issue. I've tried different things with no success.
My cap is a twist-lock job. Apparently it just gets sticky when hot and needs some persuasion to get it to come out.
