Originally Posted By: jk_636
What do I do? I am a professional mechanic of the human body and an enthusiast mechanic of automobiles. You really should stop, you could hurt someones feelings. I wish I could "garner" that much respect. But as is life. As they say, in the land of the blind, the one eyed man is king.
I'm not the one working on trying to discredit long time members, particularly ones with credentials relevant to the discussion.
First off, the term "boutique oils" is largely inaccurate. They could be more correctly classified as "high performance oils" or "superior performance oils." These oils are for the people that value superior performance, protection and detergency rather than running lower grade oils way to long just to "save money". My engine deserves the best, so it is fed the best.
That's such a load of malarkey I don't even know where to begin, but I'll certainly try:
1. Even these boutique blenders make "regular" lubricants. AMSOIL's OEM and XL oils, Royal Purple's SN oils....etc. About the only one I can think of that doesn't is Redline. They are boutique because their presence is smaller than the majors, not because their products are superior.
2. The rest of the above is hyperbole and opinion and isn't worth addressing.
3. Mobil's 0w-40 can be demonstrated as being one of the, if not THE best readily available oil on the market. Not only is it approved using the toughest OEM testing regiments but it is also the oil of choice for companies like GM, Nissan, Mercedes, Porsche and Audi in their factory race programs. It is used by a huge list of teams at LeMans and Daytona. It really IS that good. And it is also not a boutique oil because it is manufactured by a major.
A lubricant doesn't need to be manufactured by a small blender to be exceptional. And a large oil corporation doesn't produce inferior products just because they are large. What is undeniable is that the majors have more resources for extensive testing and access to more materials for blending than the small guys do. XOM is the world's largest producer of PAO base stocks. Of AN's, and a large producer of esters. They can formulate whatever lubricant anybody wants in-house using materials they simply source from themselves. This mostly applies to SOPUS, BP and the others as well.
This is not a luxury Royal Purple, AMSOIL, Redline or the other small blenders has. Redline's approach is at least relatively straight-forward: Use minimum amounts of VII's with a relatively simple blend of top-notch base oils and a very healthy additive package. They publish their product's performance specs (as does AMSOIL). Royal Purple does not do this and you are just supposed to "believe". This feels a bit like an episode of the X-files.
Without testing, all you have are claims and anecdotes. Which, conveniently, is all you've posted in this thread.
And regarding your statement that your engine deserves the best, is that what you tried to demonstrate here:
http://www.bobistheoilguy.com/forums/ubbthreads.php/topics/3630565/Mobil_5000_5w30_5,585_miles_UO#Post3630565
Where you ran Mobil 5K with MMO? Or where you state in that same thread you'll be trying PYB, Pennzoil High Mileage and Mobil 1? Why aren't you running or intending to run Royal Purple or another "superior" boutique product? Or was that statement just meant to fit with the agenda you are currently peddling?
