I took delivery of my '15 Subaru Outback 2.5i Premium today and was reading the OM. I have questions about the oil recommendations stated in the OM:
"0w-20 synthetic oil is the required oil for optimum engine performance and protection. Conventional oil may be used if synthetic oil is unavailable." Also the only viscosity listed on the temperature chart is 0w-20. It also says "5w-30 or 5w-40 conventional oil may be used if replenishment is needed but should be changed to 0w-20 synthetic oil at the next oil change."
I'm aware of some 2013 and 2014 Outback models having some oil consumption issues. Supposedly there was a piston ring flaw that has been corrected.
The car will rarely see sub-freezing temperatures. I have a big stash of 5w-20 synthetic that I'd hate to hassle with returning or exchanging.
So other than for "optimum" results or for extra CAFE mpg, why would using 5w-20 synthetic be any problem except in the case of an engine warranty claim? And if you can top off with 5w-30 or 5w-40, why would 5w-20 synthetic be unacceptable?
