Originally Posted By: SHOZ
Toluene is quite an effective octane booster and is also a major component of gasoline.
Do you realize what the spot price of toluene is? If you want to use toluene without ethanol, then your prices are going to be pretty high in today's marketplace.
The majority of commodity unleaded is already designed for blending with ethanol to arrive at a final result. Look up the acronym RBOB.
Around me all the gas is E10. The octane ratings are 87,89 and 92. So the base gas is 85, 87 and 91 octane. I believe gasoline is anywhere from 30-50% toluene now.
Doubt it's that high. The wholesale price of toluene is considerably more than refined gasoline. I'm thinking it's somewhere around $3/gallon (or at least was around last Dec). Besides that, toluene has poor volatility, so I doubt using that much is a good idea, especially with a winter fuel blend. Also - most toluene is made from refinery streams, so it's not as if unlimited amounts can be made. It's only a small fraction of the refinery output, and I noted that using up all the output to make salable fuel was basically a math exercise. And ethanol is part of that these days.
