Yes, a pipe plug socket is solid square steel, more material and stronger, a ratchet/extention has the ball in the end, and if the ratchet as a quick release, a hollow bore.
A serious mechanic has plug sockets, I have come across some dang tight differentials, and you can use a low torque impact on a pipe plug if all else fails.(risky!)
