Originally Posted By: 901Memphis
Originally Posted By: michaelluscher
They seemed good on paper, but didn't work too well or turn in a good UOA on my Taurus.
Do you have links to your uoas? I'm currently experiencing high silicon in my uoas with a PureOne air filter and Blackstone suspects an intake leak, just curious as to how high your SI is in the report I believe mine is 50+ ppm
On one of my older cars(2000 GM 3.8L supercharged engine) I found my intake leak with a little starting fluid shot in little squirts till I found the leak. It was a small hose that had a crack on the underside that I could not see. Give it a try, but just a little at a time.
ROD
