I am a bit baffled as to what happened. I let my Camry sit for nearly a week in CT--so warmer than NH. Went to start it, about noon yesterday, was prob 10F overnight and nearly freezing at noon. (was in FL, not sure what overnight temp was.) The car started to fire so I naturally let off the key. It stalled. I cranked again, and the starter sounded fast--no typ engine sounds. Cranked a couple of times, decided battery must be low and perhaps the starter was not engaging the flywheel. Got a jump pack, let it charge for a couple minutes. It might have spun faster but still no engine sounds.
Let it charge for a couple more minutes, no change, took the pack off. At this point I was out of options. What the heck, give it a good crank, then on the second time it decided to start hitting. Finally started, and smelled really rich. Ran fine afterwards.
Usually when any engine spins you can hear the speed rise and fall. I didn't hear that. Just sounded like a fast cranking speed with no compression. I will see about plugging in a computer and see if anything is stored in the ECU, no CEL but perhaps it will have something set. But any ideas as to what might have happened? I wish i had gotten some one to watch and see if the engine was spinning; I don't get why it would flood. If it happens again, would stepping on the throttle tell the ecu to cut fuel?
2011 Camry wit 2AR-FE I4, about 89kmiles. Original plugs etc.
