Dryer takes forever (3 hours or more if a decently big load) to get clothes dry - way more than normal.
Whirlpool gas dryer model GGW9250PW3 bought new in 2007
replaced thermostat p/n 8573028 on Jun-2010 from AppliancePartsPros.com
No fault/error codes in diagnostic mode
Moisture sensor test: in diagnostic mode, open door - beeps & "69" is displayed (supposedly software version) which indicates a short in the moisture sensor system.
Moisture sensor (metal strips) is bridged with finger resulting in beep & "09" displayed (supposedly software version, but why different). So initial sensor test passed.
Removed moisture sensor from the wire harness and test for resistance (the piece with the two blue MOVs). This was tested across the two outermost contacts & also across each of the outermost contacts & the center terminal (ground connection) - infinite all 3 times. So, the sensor & wire harness checks good.
Checked the resistance of the mating connector - infinite. So, the digital wire harness checks good.
Thermal fuse is not open (continuity), so good.
High limit thermostat is not open (continuity), so good.
Ran test to check thermistor connections - close door, press Control On, Press End of Cycle Signal (Louder), Start. It didn't shut off after 60 seconds nor did E1 or E2 flash in the display. So, those are good.
Checked resistance of gas coil.
3-terminal pilot measured: terminals 1-2 was 1360 ohms (spec is 1365 +/- 25), terminals 1-3 was 577 ohms (spec is 560 +/- 25) so that one is good.
2-terminal pilot measured: terminals 4-5 was 1301 ohms (spec is 1220 +/- 50) so that one is high by at least 30 ohms.
Is measuring 30 ohms too high on a gas coil enough to cause the dryer to fail? If so, then that is an inexpensive fix as the coils p/n 279834 for both primary 2 terminal & 3 terminal pilot are in stock for $16.53 from A1-Appliance.
Thanks,
Ben
Thanks,
Ben
