buddy of mine has a 98 gmc with the 5.7 vortec, 211k miles, it runs great besides a few problems. oil pressure on a cold start is 40 psi, warm idle is between 10-15 psi and cruising 50-60 mph is about 20 psi. Were trying to figure out if its the gauge, the pressure sensor, or the bearings are wore out. He says the truck has ran like that and ran just fine since he bought it with 170k. It also loses oil, sometimes the dipstick is dry, no leaking, no burning, the intake gaskets seem to be fine because the radiator and reservoir are always full. We have even tried 15W40 in it and it still loses oil. any ideas guys? I also changed the pcv valve recently..
