Code:
We're glad to see that this oil is still in service, because your Avalon barely even noticed the extra 725 miles this
oil was in service compared to the first sample. Only a measly 1 ppm extra iron showed up, and the TBN is still quite
strong at 4.7, showing active additive left (1.0 or less is too low). Insolubles are at an acceptable 0.4%, and no excess
fuel or moisture contamination is present. Run this fill up to an even 10,000 miles and check back without changing the
oil to see how things are holding up. You might go even longer after that. Looks great at 49,212 miles!
Will the oil be in grade for a 20wt in another 2000 mi?
2013 Toyota Avalon Hybrid
OIL Virgin TGMO TGMO TGM0
OIL VIS 0W-20 0W-20 0W-20
MILES IN USE 0 7413 8138
MILES on VEH 0 40814 49212
SAMPLE DATE 09/14 09/14 02/15
ALUMINUM 0 2 2
CHROMIUM 0 0 0
IRON 0 4 5
COPPER 0 0 0
LEAD 0 1 0
TIN 0 0 0
MOLYBDENUM 95 36 36
NICKEL 0 0 0
MANGANESE 0 0 0
SILVER 0 0 0
TITANIUM 0 0 0
POTASSIUM 4 0 0
BORON 4 1 3
SILICON 3 9 7
SODIUM 1 4 4
CALCIUM 2111 2182 2219
MAGNESIUM 10 14 12
PHOSPHORUS 692 668 620
ZINC 796 798 731
BARIUM 0 0 0
SUS VIS @ 210 F 46-57 53.6 50.6 49.0
cST Vis @ 100 C 6.0-9.7 8.37 7.46 6.96
Flashpoint in 0F 420 400 405
Fuel % -
Antifreeze % - 0 0
Water % 0.0 0 0
Insolubles TR 0.2 0.4
TBN 7.8 5.7 4.7
TAN
ISO Code
ALUMINUM 0 2 2
CHROMIUM 0 0 0
IRON 0 4 5
COPPER 0 0 0
LEAD 0 1 0
TIN 0 0 0
MOLYBDENUM 95 36 36
NICKEL 0 0 0
MANGANESE 0 0 0
SILVER 0 0 0
TITANIUM 0 0 0
POTASSIUM 4 0 0
BORON 4 1 3
SILICON 3 9 7
SODIUM 1 4 4
MAGNESIUM 10 14 12
ZINC 796 798 731
BARIUM 0 0 0
Fuel % -
Antifreeze % - 0 0
Water % 0.0 0 0
TBN 7.8 5.7 4.7
TAN
ISO Code
